G13BB engine stopping after changing themostat
- Verbeeck
21 Aug 2013 13:32 #80611
by Verbeeck
G13BB engine stopping after changing themostat was created by Verbeeck
Dear all,
I am experiencing a problem with my Jimny VSE FJB33 i.e with a G13BB engine.
The previous owner removed the thermostat certainly because the engine stopped intermittently.
now that I want to put the thermostat back, the engine stops before it gets to the ideal temperature.
When pouring water on the CAM sensor, the engine restart fine.
Do you think replacing the CAM sensor will fix the problem?
Thank you and best regards.
- markyp2000
21 Aug 2013 14:04 #80614
by markyp2000
Replied by markyp2000 on topic G13BB engine stopping after changing themostat
Yes its worth a try
21 Aug 2013 14:54 #80620
by j999pre
Grey pick up Jimny
Replied by j999pre on topic G13BB engine stopping after changing themostat
I second that. Give it a try. Do you know anyone with one you could try out of a known good engine?
Grey pick up Jimny
The following user(s) said Thank You: Verbeeck
- Verbeeck
22 Aug 2013 05:01 #80702
by Verbeeck
Replied by Verbeeck on topic G13BB engine stopping after changing themostat
Thanks for your answers !
Unfortunately I don't know anyone with a Jimny.
To resume my situation, I live in Mauritius Island, I purchased the Jimny as my first Own car.
Everything was fine except the temperature gauge that remain low except in traffic jams.
After refilling the tank, (full tank) i noticed that it only last for 350 kms. (I tried 355 kms , and unfortunately had to get back home by foot
After running through forums and discussion to find out how to reduce fuel consumption, i have learned that there is a Gamma sensor that enhance the fuel mixture when engine is cold.
The previous owner removed the thermostat so the engine remain always cold, increasing that fuel mixture and raping my wallet
So I decided to buy a new thermostat , fitted it in the car, started the engine for few seconds, engine stopped.
I first thought it was because the new thermostat was faulty, I bought a new one, same problem.
When pouring water on that CAM sensor, the engine could restart easily.
I have spent all my money in the repairs of that car:
firstly, when braking it tended to go left. i thought it was the brake caliper piston that needs a repair kit.
there was no repair kit available but I had the opportunity to buy a pair of caliper piston with all the seals.
Then when trying to replace the part, I noticed the was a oil leak from the Kingpin that was leaking on the disk.
Had to replace the kingpin kit. :huh:
cost me an arm :ohmy: .
so now i really hope the problem comes from the Cam sensor as my budget is tight and i can't afford other expenses on the jimny. (i hope it will fix my heating problem so i can fit the thermostat and reduce my fuel consumption).
thanks for reading
thanks for reading
- Verbeeck
22 Aug 2013 05:54 #80703
by Verbeeck
I found that cam sensor on Ebay :
www.ebay.com/itm/230620483070?ssPageName...id=p3984.m1438.l2649
do you think it is the good one ? (about $50)
the suzuki agency asked me $265 for a new one :ohmy:
thanks for your replies
Time to create page: 0.084 seconds
