Difference in wheel position in wheel arch?
- minibbb
13 years 2 months ago #80486
by minibbb
Difference in wheel position in wheel arch? was created by minibbb
- markyp2000
13 years 2 months ago #80487
by markyp2000
Replied by markyp2000 on topic Difference in wheel position in wheel arch?
The trim dont look like its fitted correctly
- supergaz
13 years 2 months ago - 13 years 2 months ago #80488
by supergaz
Replied by supergaz on topic Difference in wheel position in wheel arch?
Also is the car sitting level? Looks as if its on uneven ground.
Last edit: 13 years 2 months ago by supergaz.
- Paul4x4
13 years 2 months ago #80499
by Paul4x4
If the axle really was in some crooked position, then you would see some significant damage to the trailing arm and it's mounts. So, if everything looks ok under the truck, then I wouldn't be too worried.
Replied by Paul4x4 on topic Difference in wheel position in wheel arch?
My first thought too!markyp2000 wrote: The trim dont look like its fitted correctly
- reaper
13 years 2 months ago #80504
by reaper
Replied by reaper on topic Difference in wheel position in wheel arch?
If you have cc bushes fitted check them as they can ''spin'' and cause the radius arms to sit at different points
13 years 2 months ago #80505
by jimkyx
Replied by jimkyx on topic Difference in wheel position in wheel arch?
The following user(s) said Thank You: minibbb
Time to create page: 0.090 seconds
