Panhard rod
  • Reckerr
13 years 3 months ago - 13 years 2 months ago #80274 by Reckerr
Panhard rod was created by Reckerr
New here with a fully stock 2000 Jimny except for 215/75r15. Just a question about the panhard rod at the back i think thats it.
Is it supposed to be fully straight...I....accidentally got the back out in the rain a bit too much last night and ended up facing the other direction. I thought the tyre took most of the blow but on inspection this morning.
The rear driver side wheel is almost 1" further out and the passenger is 1" further in. (cant see passenger side from just looking it's down in the body.)
I looked underneath...and the panhard rod is like a /\ . Is it supposed to be straight. It's even touching the "box part./muffler" of the exhaust...
Is this expensive to fix?
Thanks
Last edit: 13 years 2 months ago by Reckerr.
  • JivingDaddy
13 years 3 months ago #80278 by JivingDaddy
Replied by JivingDaddy on topic Panhard rod
Well, mine looks straight - and so does this:
BigJimny
It seems Martin doesn't sell them and, unless you intend doing some tough off-roading, the replacement heavy duty from off-road armoury coould be an overkill at 165 quid! Replacement Panhard Rod
Don't panic, an expert will be along soon to advise you further.
  • ChrisM
13 years 3 months ago #80288 by ChrisM
Replied by ChrisM on topic Panhard rod
Kap Suzuki do aftermarket adjustable Panards for £95+vat but you need new bushes to fit to them, another option is Cam Suzuki who break Jimnys they may have a panhard rod or 2 and theres always eBay offcourse.
Looking in the service manual it appears that it should be straight.
  • Reckerr
13 years 3 months ago #80301 by Reckerr
Replied by Reckerr on topic Panhard rod
Definitely bent........oh dear. I'm from barbados in the Caribbean and since these don't sell in the states. I either have to see how much it would be to get here.
Or see if i can get my hand on a second hand one..there are plenty of hired Jimny's here. Ill post a picture of my jimny so you can see it
Probably dont intend to but is straightening a no no?.
  • ChrisM
13 years 3 months ago - 13 years 3 months ago #80305 by ChrisM
Straightening is an option, I believe its only thin tube though so may not straighten to well and might be best done with a little bit of heat, I can't really see any problem with that unless to intend to do some heavy offroading at which point it might be too weak to handle the stresses, but for the road it should be ok.
Another option is getting a workshop to make you a new one if you can't get one locally, its just 1 long tube with two short bits of tube welded onto each end and then rubber bushes in the 2 short pieces, or swop the 2 end tubes for spherical bearings that can crew in and out to adjust the length.
Last edit: 13 years 3 months ago by ChrisM.
  • Reckerr
13 years 3 months ago - 13 years 3 months ago #80309 by Reckerr
Called the local(only) dealership for Suzuki here on the island and got quoted $279.13 bushes everything included. Equivalent to about 92.04 pounds. So I assume that's ok at best. Ill see if I can get a used one for a cut price in good condition but then I would need new bushes and get them pressed in right...?
I'm fairly new to all the mechanic talk so bear with me if I make errors. I welcome all corrections.
Can you buy bushes separately?
Last edit: 13 years 3 months ago by Reckerr. Reason: Added info.
Time to create page: 0.103 seconds
