my jimny has developed a problem
- jonnyboy
14 Aug 2013 09:16 #79848
by jonnyboy
my jimny has developed a problem was created by jonnyboy
Hi looking for some advice my jimny has started to cut out when driving it starts fine heats up well runs for about 18 miles then cuts out the imobaliser light flashes then it shuts down then if left fir a few minutes it starts and runs again for another few miles then does the same again had it on the computer to check it but it is only showing a fault fir the alamda sensor
- markyp2000
14 Aug 2013 09:41 #79853
by markyp2000
Replied by markyp2000 on topic my jimny has developed a problem
May be a cam or crank sensor what engine do you have is it a twin cam or single cam
- UKDAN
14 Aug 2013 17:36 - 14 Aug 2013 17:38 #79879
by UKDAN
Replied by UKDAN on topic Re:my jimny has developed a problem
Coil pack breaking down when hot causing misfire on 2 cylinders & stalling engine ?
Dan
Dan
Last edit: 14 Aug 2013 17:38 by UKDAN.
14 Aug 2013 19:39 #79894
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re:my jimny has developed a problem
M13a I bet. Crank sensor. Search on here. Loads of info on it.
Grey pick up Jimny
Time to create page: 0.086 seconds
