knocking sound when turning
  • TomDK
13 years 3 months ago - 13 years 3 months ago #79711 by TomDK
knocking sound when turning was created by TomDK
Hi,
I'm experiencing strange knocking sounds, I believe it's from the rear axle.
The sounds mostly occur when entering a roundabout and weight shifts to one side. And then again when weight shifts to the other side of the car, exiting the roundabout.
I've been looking at the bushes on panhard rod and radius arms with a crowbar, to see if there were and freeplay or anything. But everything looks fine.
What can cause these sounds, if not radius arms and/or panhard rod?
Last edit: 13 years 3 months ago by TomDK.
  • supergaz
13 years 3 months ago #79716 by supergaz
Replied by supergaz on topic knocking sound when turning
Top shock mount bolt loose? Elongated holes on axle mount brackets? Elongated panhard mounts on axle or chassis?
  • TomDK
13 years 3 months ago #79718 by TomDK
Replied by TomDK on topic knocking sound when turning
Thanks, will look into that first thing in the morning :-)
  • markyp2000
13 years 3 months ago #79721 by markyp2000
Replied by markyp2000 on topic knocking sound when turning
Some thing rolling around in the jack area or
The nut loose behind the wheel :-)
13 years 3 months ago - 13 years 3 months ago #79734 by j999pre
Replied by j999pre on topic knocking sound when turning
Head banging on the window? To check send the window down and try again. If the knocking has gone you have found your problem!
Sorry ;)
Grey pick up Jimny
Last edit: 13 years 3 months ago by j999pre.
Time to create page: 0.095 seconds
