Panhard rods's effect on steering.
  • macguyverjimny
12 Aug 2013 12:08 #79661 by macguyverjimny
Panhard rods's effect on steering. was created by macguyverjimny
Hi guys,
I would like to know if the incorrect length panhard rod can effect the stability and stearing of the jimny?
I think the front and rear axles might be a bit off centre,
Neather of the springs catches on the chassis, but still,
So in other words, if the rear axle is a bit more to the left or right than the front axle or vice versa, can this effect the stearing and stability when driving in a straight line, ?
Sometimes on road the jimny when driving in a straight road i can feel the can sometimes feel a bit loose on the road ,the jimny will just suddenly lean to a side for a small peroid of time, can this be the panhard or rather the caster?
I would love to get some replies , i know the problem seems very vague, There might be someone with a lottle experience on this,
Thank you.
  • markyp2000
12 Aug 2013 12:48 #79664 by markyp2000
Replied by markyp2000 on topic Panhard rods's effect on steering.
If the panard rods are as us discribed the it wont run straight it would look like it was crabbing and would drive like poo also caster can have affect on the drive as well
  • macguyverjimny
12 Aug 2013 12:58 #79666 by macguyverjimny
Replied by macguyverjimny on topic Panhard rods's effect on steering.
Thank you,
Is there a way to measure how close to centre my axles are? Other than looking at it with the eye?
I have caster correction bushes i know its not 100% sufficient but it corrects it a little right!?
Any help would be appreciated :)
Thanks for the reply
  • barnes
12 Aug 2013 14:03 #79671 by barnes
Replied by barnes on topic Panhard rods's effect on steering.
Measure from chassis to rim each side youll tell how far your out then. Id deffo look into radius arm tho
  • macguyverjimny
12 Aug 2013 14:44 #79674 by macguyverjimny
The rear axles is about 10mm off centre to the left, it is a right hand drive,
So the front one differ n further 3.5 mm from the rear one also to the left,
So if i draw a centre line in the middle of the two chassis beams, then the front is about 13,5mm to the left and the rear about 10mm to the left,
If these are correct would i experience a difference in the handling /stability of my car?
Thank you.
  • macguyverjimny
12 Aug 2013 19:27 #79697 by macguyverjimny
Can this cause bumpsteer?
Time to create page: 0.149 seconds
