Removing driveshaft
  • Pastychomper
13 years 3 months ago #79337 by Pastychomper
Removing driveshaft was created by Pastychomper
The time has come to change the clutch and we're working our way through the instructions - I'm not the greatest mechanic but fortunately have some more competent help for a day or two. :P This is a twin-cam engine from about 2001.
We've taken all the bolts out of both ends of the front driveshaft, but it's still not coming out and doesn't even appear loose. There's quite a bit of corrosion that might be holding it in place. The transfer shaft is also refusing to budge, and doesn't seem to be corroded.
Is there a trick to getting it out, or do we just need to hit it harder?
Thanks
  • markyp2000
13 years 3 months ago #79338 by markyp2000
Replied by markyp2000 on topic Removing driveshaft
Hit it harder there is a little lip on the inside to center it and thay stick on that
Time to create page: 0.071 seconds
