Air Conditioning Problem
  • mikecarroll
07 Aug 2013 17:57 #79283 by mikecarroll
Air Conditioning Problem was created by mikecarroll
On my 2010 Jimny the compressor cuts in and out - sometimes every few seconds. This happens from start and as it's 85f currently it can't be because it has become over cold !!! The AC also works when in 4WD, I didn't think this should happen. Lastly is the engine so lacking in power that you should feel the reduction in speed (when travelling at say 30mph) when the compressor kicks in??
Any help would be appreciated.
  • barnes
07 Aug 2013 18:02 #79284 by barnes
Replied by barnes on topic Air Conditioning Problem
Its going out on low pressure. Any yes when a compressor kicks in ul feel a power drop
  • markyp2000
07 Aug 2013 18:14 #79286 by markyp2000
Replied by markyp2000 on topic Air Conditioning Problem
Is it blowing cold if so no problem
The air con pump will kit in and out and its only a 1.3 so will draw power away
As for working in 4wd iv hurd its ment to cut out i will check on my other jimny with air com tomorrow and let you no but mine is a T reg and it has factory fitted air con after it was brought by the previous owner
  • mikecarroll
07 Aug 2013 18:37 #79289 by mikecarroll
Replied by mikecarroll on topic Air Conditioning Problem
If it's going out on low pressure does that suggest the system needs recharging?
  • barnes
07 Aug 2013 20:11 #79297 by barnes
There will be a problem if the compressor going out to often it can lead the compressor coil to fail, yes usually if the unit is not run for a period of time refrigerant will pass from the compressor seal as it is shaft driven. When the unit is running refrigerant/oil will lubricate the seal and stop the leak. The usual process is recover gas pressure test using moisture free nitro, locate leak evacuate and re-weigh the refrigerant into the liquid side(failure to charge this way will fill the compressor full of liquid and damage valves!) Refrigerant used is r134a
  • markyp2000
07 Aug 2013 21:51 #79316 by markyp2000
The pump will click in and out to regulate the temp so as not to get to cold inside and dry the air out to much as air con removes mosture from the air
It may have a fault(low gas) it may not but get it checked out by a qualified aircon guy NOT some where like kwikfit and hen you will no what is wrong
