my props are too long?
  • ne-crock
03 Aug 2013 18:46 #78868 by ne-crock
my props are too long? was created by ne-crock
my props are too long so i'm having no joy with fitting this box this evening,
anyone came across this problem before?
  • Dave cc
03 Aug 2013 18:57 #78870 by Dave cc
Replied by Dave cc on topic my props are too long?
fornt ? rear ? middle ? thought they were to short with a lobster you have got SJ props ?
  • ne-crock
03 Aug 2013 19:10 #78872 by ne-crock
Replied by ne-crock on topic my props are too long?
middle is 12mm to short, fitted my spacer thats okay,
i'm using my jimny front prop with an sj flange to bolt straight to the tbox
rear is a sj prop with a jimny flange to bolt straight to the diff
  • vitara_mad
03 Aug 2013 19:50 #78878 by vitara_mad
Replied by vitara_mad on topic my props are too long?
if he sj rear prop you got is too long then you have got a 410 prop & you need a 413 as they are slightly shorter
  • ne-crock
03 Aug 2013 19:52 #78879 by ne-crock
okay, i'll see what i can sort
what about the front prop?
  • vitara_mad
03 Aug 2013 21:12 #78885 by vitara_mad
is your standard jimny front prop too long ???
have you got susp lift with no caster correction ????
