Reverse gear failed
- Nanteos
03 Aug 2013 17:46 #78863
by Nanteos
Reverse gear failed was created by Nanteos
I have a standard 2008 Jimny that does no hard work. Its done 27000mls. Suddenly it wouldn't go into reverse, grinding noises etc. Ive had it back to the dealer under warranty and they have renewed a "chipped reverse gear and some bearings on that shaft". What do you think could have caused this? Is this a common thing,
I haven't seen any mention of it on the forum.
It does make a bit of noise from the transmission, whirling sort of, as it always has under load. How much noise is there normally from the gears and prop. in 2 wheel drive I wonder?
- markyp2000
03 Aug 2013 19:40 #78875
by markyp2000
Replied by markyp2000 on topic Reverse gear failed
May need the clutch cable adjusting and the noise maybe due to no oil or low oil or wrong oil
Time to create page: 0.132 seconds
