2nd gear vibration
  • talisman
13 years 3 months ago #78337 by talisman
2nd gear vibration was created by talisman
Hi all, new to Jimny's but bought one recently and love it to bits. BUT, when I change from 1st to 2nd with any load on the engine there is a bad vibration from somewhere. Fitted new rear prop coupling thinking that would cure, but no. It will do it in pretty much any gear if you put enough load on, but 2nd is the annoying one. You have to really get it moving before you change up to avoid the vibes, by that I mean at least 20mph in 1st. Any ideas out there?
  • markyp2000
13 years 3 months ago #78339 by markyp2000
Replied by markyp2000 on topic 2nd gear vibration
Whats the engine rpm when vibrating
  • Stan
13 years 3 months ago #78340 by Stan
Replied by Stan on topic Re:2nd gear vibration
Check the gearbox mounts first bud
Sent from my Nexus 7 using Tapatalk 4 Beta
  • talisman
13 years 3 months ago #78344 by talisman
Replied by talisman on topic 2nd gear vibration
Hi, revs are between 1400 and 1800.
  • talisman
13 years 3 months ago #78346 by talisman
Revs between 1400 and 1800.
  • markyp2000
13 years 3 months ago #78347 by markyp2000
Rev it a bit higher then both mine would vibrate at that rpm changing gear
Time to create page: 0.088 seconds
