Rear wheel spinning...
  • Muzza904
24 Jul 2013 20:59 - 24 Jul 2013 21:05 #78120 by Muzza904
Rear wheel spinning... was created by Muzza904
So i was changing my drum break pads tonite and had the back wheel off the ground. At some point I ended up turning the engine on and with it idleing in neutral the rear hub was whirring round and required a fair amount of force to stop it?? Does this mean my clutch is going or what? Also when my car is sat in neutral it makes a whirring noise but dip the clutch and it goes quiet. Just wondered if anyone might know. Thanks in advance :)
Sent from my GT-I9300 using Tapatalk 4 Beta
Last edit: 24 Jul 2013 21:05 by Muzza904.
  • markyp2000
24 Jul 2013 21:15 #78122 by markyp2000
Replied by markyp2000 on topic Rear wheel spinning...
It normal on some cars for the wheels to turn
The noise may be the release bearing
  • Muzza904
25 Jul 2013 07:55 #78131 by Muzza904
Replied by Muzza904 on topic Rear wheel spinning...
Dont know much about clutches but im guessing you mean the release bearing for the clutch? Easy to fix or replace?
  • markyp2000
25 Jul 2013 09:43 #78134 by markyp2000
Yer thats the one you have to remove the gearbox to replace it you may be able to get it on its own or just fit a new clutch kit its up to you my other car lasted 5 year with a noisey bearing then it just broke up
  • Muzza904
25 Jul 2013 11:51 #78149 by Muzza904
Replied by Muzza904 on topic Re:Rear wheel spinning...
Well I hope it lasts me that long dont really feel like learning how to change a clutch on my own car for the first time haha. Cheers
25 Jul 2013 12:21 - 25 Jul 2013 12:22 #78151 by facade
Replied by facade on topic Rear wheel spinning...
Whichever wheel is easiest to turn will go round, it is how the differential works
Made in The Olden Days when cars were built properly.
If you had the other wheel on the ground and managed to stop the spinning wheel,, it should have driven off the jack :ohmy:
The noise may be the release bearing, or it may just be wear in the gearbox, do check the gearbox oil level. ;)
Last edit: 25 Jul 2013 12:22 by facade.
