Need some flexy brake pipe advice
- S Mark
13 years 3 months ago #78030
by S Mark
Need some flexy brake pipe advice was created by S Mark
Hi folks a newbie here
just bought a 03 Jimny and after lots of oily T.L.C and evenings smelling of gear oil, hammerite and stone guard, :laugh: I am looking to get a body lift from jimnybits, in the proces of fitting i will be removing the antie role bars but i also want to fit the jimnybits flex metal brake pipes, But when i save a fue more pennies i was going to invest in a 3" suspension lift. so my question is will these flex brake pipes be to long for just a 2" body lift?? or not long enough when i do the 3" lift later on?? if that makes an seine at all?
- Vacneb
13 years 3 months ago #78031
by Vacneb
Replied by Vacneb on topic Need some flexy brake pipe advice
I got mine direct from LAMA4x4 who apparently supply jimnybits?!?!
If they are the same - the chap at LAMA reckons they are good for a total of 5 inches of lift (be it body, suspension or both)
I fitted mine with a 2 inch suspension lift alone and they are absolutely fine!
- markyp2000
13 years 3 months ago #78038
by markyp2000
Replied by markyp2000 on topic Need some flexy brake pipe advice
You dont need to replace the pipes when doing a body lift the only flexi pipes you have to adjust are the ones on the drivers side above the trailing arm between the body and chassis
Just unbolt the mount do the body lift then make a plate to refit them
- S Mark
13 years 3 months ago #78108
by S Mark
Replied by S Mark on topic Need some flexy brake pipe advice
Thanks for the heads up guys, maybe ill get some wheel spacers insted.
Time to create page: 0.079 seconds
