loud nocking under accelerationg or load
  • ne-crock
13 years 3 months ago #77659 by ne-crock
So my cars nocking like crazy if the cars accelerating or any load on the drivetrain e.g up slight hills,
i thought it was my tbox mount because that was cracked anyway its replaced and still continuing,
any ideas please?
to me it sounds like its from the front of the car, maybe gear box or something on the n/s wheel
  • markyp2000
13 years 3 months ago #77660 by markyp2000
Replied by markyp2000 on topic loud nocking under accelerationg or load
Take the nuts off your trailing arms and see it any of the holes are elongated also see if you can push the rear of the gear box up to see if the mount is shot and see if there is any slop in the prop and rear diff
  • ne-crock
13 years 3 months ago #77664 by ne-crock
Replied by ne-crock on topic loud nocking under accelerationg or load
its not a single nock like the arms moving to the back of the elongated holes its a continuos nocking untill the loads released from the drive train, i'll have a look though,
how much play should be in the g-box and the diffs and prop?
none at all or a small amount?
  • markyp2000
13 years 3 months ago #77666 by markyp2000
Small amount
What about the exhaust are all the mounts intack and not knocking on the chassis
Or it could be the t box chain slipping :-(
  • ne-crock
13 years 3 months ago #77670 by ne-crock
i can press the gear box up about 5-6mm at a guestimate,
prop in gear has about an 1/8th of a turn? uj's seem okay,
exhausts okay recently redid the mounts on it,
i hope its not the tbox -_-
  • markyp2000
13 years 3 months ago #77673 by markyp2000
Its not the engine knocking is it
Check ya oil and rev it hold it at each thousand but dont red line it and see if it knocks :-(
