Front propshaft remove.Help please,
  • macguyverjimny
18 Jul 2013 10:29 #77418 by macguyverjimny
Front propshaft remove.Help please, was created by macguyverjimny
Hi guys,
I am struggeling to remove the transfer part of the jimny propshaft to fit the spacer, i removed all 4 bolts.Now the shaft's end is still stuck to the output flance of my transfer, can someone please assist?
The transfer is still in 2wd,
Is there some other bolts or a trick or something!?
Will there be something in the service manual that i missed?
Please help, :)
Thank you.
  • barnes
18 Jul 2013 10:39 #77419 by barnes
Replied by barnes on topic Front propshaft remove.Help please,
I put my spacer on the diff end of the shaft. It should pull back slighty i cant remember if the flange has a slight locating lip
  • Dave cc
18 Jul 2013 12:00 #77429 by Dave cc
Replied by Dave cc on topic Front propshaft remove.Help please,
Pry bar it back or a Damn good twack with a soft face mallet don't worry you wont damage it :)
  • markyp2000
18 Jul 2013 12:28 #77431 by markyp2000
Replied by markyp2000 on topic Front propshaft remove.Help please,
The front spacer goes on the t box end to push it out over the cross member like dave said hit with a hammer and if the prop shaft slip joint comes off make shore its lined up correctly with the other end
  • macguyverjimny
19 Jul 2013 10:57 #77530 by macguyverjimny
Replied by macguyverjimny on topic Front propshaft remove.Help please,
Got it off :) used a tie down strap :)
Thank you all :)
