Gearbox Leak
13 years 4 months ago #77392
by Jackson
Gearbox Leak was created by Jackson
Hi folks.
I am a Jimny owner for approx 4 years. Mostly on road use and country lanes.
About a month ago a whining noise was diagnosed by Suzuki as a manual gearbox fault caused by low oil level in gearbox due to a leak. I had no indication there was a leak.
I have cleaned up around the gearbox and filled the gearbox back up. Also added 125ml of stop leak (Wynns).
This has reduced the noise significantly although I am still observing a small leak from somewhere.
There is no noise/vibration apparent at idle (with/without clutch depressed).
My next plan is to add some Lucas oil stabiliser to see if that helps.
Has anyone got any advice on this issue? I am trying to repair without dropping the gearbox out as I do not have the facilities to do this at home.
Price to inspect the gearbox is £250 plus labour and parts.
I probably score 3/5 spanners, so keep it simple for me. Thanks.
- markyp2000
13 years 4 months ago #77394
by markyp2000
Replied by markyp2000 on topic Gearbox Leak
Where are you located there may be some one on here local to you that could help
13 years 4 months ago #77396
by Jackson
Replied by Jackson on topic Gearbox Leak
Northern Ireland
- gilburton
13 years 4 months ago #77436
by gilburton
Replied by gilburton on topic Gearbox Leak
If it's a VVT model it could be the propshaft as these are known to be faulty but there will be oil thrown off the prop on to the underneath of the car or possibly a burning/hot oil smell from oil on the exhaust.
13 years 3 months ago #77567
by Jackson
It is VVT. I cleaned up the underside and so far the only leak is a small drop running off the gear lever support link arms. Very small. The exhaust does run beneath the leak.
When you say the propshaft is known to be faulty - what does that mean? What is the repair?
Thank you.
Thank you.
- gilburton
13 years 3 months ago #77573
by gilburton
It's the adhesive that holds on the circular tube that covers the sliding part where the prop goes in the gearbox.
It's a known problem and most owners have had it replaced under warranty. I think my car was such low mileage it wasn't picked up under normal use??
I had to pay for mine
Suzuki's cure is a new output seal on the gearbox and a new prop shaft.
Initially I had the output seal replaced but it leaked again so I went the whole hog and had it replaced again and a new prop but the garage only charged for the parts as they had done the original job.
This link might explain it better?
www.bigjimny.com/index.php/forum/7-jimny...-leaking-again-grrrr
Time to create page: 0.089 seconds
