ecu change
  • 410shotgun
13 years 4 months ago #77188 by 410shotgun
ecu change was created by 410shotgun
hi all if I get a s/hand ecu for my jimny
all the same numbers and same year
will it work or is it chiped
can anyone help
  • Vacneb
13 years 4 months ago #77189 by Vacneb
Replied by Vacneb on topic ecu change
think with an ECU change you may need a new ignition barel, which means new door locks if you want them keyed alike?!?!
  • vitara_mad
13 years 4 months ago #77197 by vitara_mad
Replied by vitara_mad on topic ecu change
you need to swap ecu, imobilizer unit, ignition for it to work
  • 410shotgun
13 years 4 months ago #77212 by 410shotgun
Replied by 410shotgun on topic ecu change
ok thanks
  • markyp2000
13 years 4 months ago #77236 by markyp2000
Replied by markyp2000 on topic ecu change
Or send it away to have the imobilizer code cleared from the ecu and unplug the imobilizer unit
  • 410shotgun
13 years 4 months ago #77263 by 410shotgun
ok where is the imobilizer unit
also do i need to change the ring around the steering lock
Time to create page: 0.094 seconds
