Steering Box Rusty
  • i5jimny
12 Jul 2013 18:38 #76881 by i5jimny
Steering Box Rusty was created by i5jimny
Just noticed today when checking over the car, the steering box and pipes are extremely rusty as is the front panel. I have shown this in a couple of pics and just wondering if I should be concerned. There is a bit of foam loose that is hanging over the steering box and my daughters boyfriend who is a mechanic thinks that possibly water was dripping off this on to the box and pipes. Just wondering if this level of rust on the box and front panel would be acceptable for a 57 plate car. Been concerned about this all day, also had 2 front shocks fitted and rear wheel bearing, again is this normal wear & tear or does it point to a hard off road life. Be grateful for any thoughts from people that know these cars.
  • vitara_mad
12 Jul 2013 18:42 #76882 by vitara_mad
Replied by vitara_mad on topic Steering Box Rusty
nothing looks unusual there
  • GuardianAngel
12 Jul 2013 18:44 #76884 by GuardianAngel
Replied by GuardianAngel on topic Steering Box Rusty
Jimnys are painted with brine it seems! Really bad design that allows mud and water to settle and rot.
For a 57 plate I would say its not acceptable but it maybe surface rust. If you were inclined you maybe able to wire brush it away and protect with non-salt based paints :)
  • i5jimny
12 Jul 2013 18:46 #76885 by i5jimny
Replied by i5jimny on topic Steering Box Rusty
Thanks for that, my mind is gradually easing. I really like the car and realise it is 6 years old but just want things to be as good as can be. The older I get the more I worry about things,(never thought I'd see that day!)
  • i5jimny
12 Jul 2013 18:49 #76888 by i5jimny
Suppose if the worst happened I could replace the steering box sometime, but was hoping to try & clean it up and coat it with dirty oil or some such. Was thinking of taking front bumper off and rubbing down and coating front panel, would that be feasible and worth it? Daughters boyfriend suggested sanding rust away and painting it black.
  • vitara_mad
12 Jul 2013 18:52 #76889 by vitara_mad
strip the front end & clean rust up a bit & treat with some rust cure stuff then paint it
