wheel bearing help
- idiotmobil
13 years 4 months ago #76772
by idiotmobil
wheel bearing help was created by idiotmobil
ive ordered one side wheel bearing and got them today and ive been suplyed with two tapered bearings im sure this isnt correct can any one help with conferming this before i send back or go ahead with replacing as havnt got the time to do it twice
- markyp2000
13 years 4 months ago #76774
by markyp2000
Replied by markyp2000 on topic wheel bearing help
Post a pic you may have king pin bearings how big are thay
- idiotmobil
13 years 4 months ago #76783
by idiotmobil
Replied by idiotmobil on topic wheel bearing help
not kingpin bearing twice the size of them ive got some kingpin bearings here looks to be about thee right size but isnt the wheel bearing one big bearing thats quite deep
13 years 4 months ago #76805
by j999pre
Grey pick up Jimny
Replied by j999pre on topic wheel bearing help
Alot of motor factors get it wrong. Send it back and get one from martin on here you will know it is right then.
Grey pick up Jimny
- GuardianAngel
13 years 4 months ago #76815
by GuardianAngel
Replied by GuardianAngel on topic wheel bearing help
Who did you order it from? Was it from the BJ shop?
If so then your are probably OK. I ordered a bearing from Martin a few months ago and it turned out to be a tapered version. Anyway, I contacted Martin who looked into it and found out that they had changed the design so they fit the Jimny hub correctly. So, I fitted it and its been fine. No issues with bad fitment or failing. It was fitted using a bearing press at a garage.
But bear in mind the bearing was good coming from the BJ shop. If you have purchased it elsewhere then it might not be.
Time to create page: 0.089 seconds
