Starter starting to stop?
- Pastychomper
Usually after 10-20 seconds the noise stops and the engine starts normally. Once it didn't, even after several attempts, and the battery negative terminal became very hot to touch - but I'd just reconnected the battery and there was some corrosion around the terminal, so that might be a coincidence.
Any suggestions on what might need checking, or shall I go ahead and replace the starter? As it happens I'm planning to change the clutch soon (wish me luck...
- ZookFastback
Hope it comes good for you.
- Dave cc
ZookFastback wrote: Try the simple things first. Could be loose battery connections, could be loose connection to starter. Next time it happens turn the headlights on and see if they are fully bright. If they aren't, poor a cup of very hot water over the terminals and see if that improves things. If it does, remove, clean and dry and spray with RP7, CR-C or similar product.
Well said and your engine to body earth strap as well
- markyp2000
Failing all th above posts long bit of wood and tap it with a hammer while some one cranks it over
- gus2000
- Pastychomper
