Fitting manually operated freewheeling hubs
  • helijohn
24 Jun 2013 22:51 #75005 by helijohn
I did a search but found nowt really useful apart from a link to the Jimny shop which is now closed. Can anybody tell me what is involved in fitting manual operated freewheeling SJ hubs please if they have the time..
  • ne-crock
24 Jun 2013 23:45 #75006 by ne-crock
Replied by ne-crock on topic Fitting manually operated freewheeling hubs
With the sj hubs you need the 10mm spacer to make them fit,
Once you have that, its litterally the case of unbolt the vacum hubs,
Then bolt your manual hubs using the spacer, make sure your hubs come with the cone washers if not they are available on jimny bits
Other people have then removed vacum lines and blocked holes to stop water/dirt ingress i have left them alone to keep the dirt out
Its a really simple job, but the manual hubs are worth their weight in gold
  • helijohn
25 Jun 2013 07:06 #75010 by helijohn
Replied by helijohn on topic Fitting manually operated freewheeling hubs
ne-crock wrote: With the sj hubs you need the 10mm spacer to make them fit,
Thanks. That is really helpful and it looks like a very doable job. Do you know if the Vitara 1600 ones will fit? Thanks for the link to jimnybits. I can't find a spacer supplier now. :blush:
  • ne-crock
25 Jun 2013 08:23 #75013 by ne-crock
www.jimnybits.co.uk/shop/jimny/drivetrai...plates/prod_610.html
Again jimny bits supplt them
I believe they do fit, but i'd get confirmation on that,
I'm running asin sj hubs
  • UKDAN
25 Jun 2013 08:46 #75014 by UKDAN
Yes Vitara hubs fit & you still need the spacer ring.
Dan
  • helijohn
25 Jun 2013 08:56 #75016 by helijohn
Replied by helijohn on topic Re:Fitting manually operated freewheeling hubs
UKDAN wrote: Yes Vitara hubs fit & you still need the spacer ring.
Dan
Brilliant, you are a star.
Time to create page: 0.105 seconds
