Rust in jack well.
  • Orangeherald
21 Jun 2013 22:23 #74624 by Orangeherald
Rust in jack well. was created by Orangeherald
I am sure this will come as no surprise to most of you! I was aware that Jimnys are prone to rust in the well where the jack is kept, but did not know why until today. I was cleaning inside my 05 Jimny, and I spotted three rust blisters, where the spot welds are. A few minutes with a dremel and a sanding drum told me the story. The inside layer was through in three spots about as big as a finger nail, but the underneath layer is fine. Looking underneath I find the double layer at the point above the silencer is provided with two holes about 10mm to allow water in to the area where spot welding has removed any protection from the steel, and is a superb area for holding salty water and the heat from the silencer ensures it works its magic. Lovely bit of design Suzuki! Cleaned up inside and smoothrited at once. Then underneath with waxoil aerosol and a long pipe. Cavity blasted with waxoil, so that should slow the rot down at least! Now I am going to go all round looking for more such areas and cavities. Waxoil shares will be up no doubt.
22 Jun 2013 00:16 #74630 by facade
Replied by facade on topic Rust in jack well.
There is a double skin under the rear seatbelt mountings, and a double skin cavity at the vertical wall under the front of the back seat.
The jimny has so many double skinned rust traps that I think Alec Issigonis might have helped design it :ohmy:
  • UKDAN
22 Jun 2013 07:29 - 25 Jun 2013 09:26 #74636 by UKDAN
Replied by UKDAN on topic Re:Rust in jack well.
I think the reason it rusts just there is cos its right above the back box and there's no heat shield there so the constant heating & cooling causes condensation to form inside which builds up so you have water sitting there & over time causes it to rust
Dan
Last edit: 25 Jun 2013 09:26 by UKDAN.
  • Orangeherald
22 Jun 2013 09:46 #74647 by Orangeherald
Replied by Orangeherald on topic Rust in jack well.
facade wrote: There is a double skin under the rear seatbelt mountings, and a double skin cavity at the vertical wall under the front of the back seat.
It certainly brought back memories of 1960's cars! Thanks for that, I will have some "fun" exploring all those dark corners. Maybe better get a lot more waxoyl... :whistle:
  • helijohn
24 Jun 2013 22:20 #75001 by helijohn
Replied by helijohn on topic Re:Rust in jack well.
UKDAN wrote: I think the reason it rusts just there is costs right above the back box and there's no heat shield there so the constant heating & cooling causes condensation to form inside which builds up so you have water sitting there & over time causes it to rust
Dan
There's a rubber bung in a hole and I wonder if it is better to remove it so any water can just drain out. I undersealed mine which reminds me; got to get a bottle jack. :laugh: :laugh: I still think I should get a can opener and just remove that well. ;)
Time to create page: 0.159 seconds
