Spacers
- pkitchen123
13 years 5 months ago #74110
by pkitchen123
Replied by pkitchen123 on topic Re:Spacers
The torque setting is 70lb/ft , just checked the packaging in the box mine came in. Hope it helps.
- jimnydms
13 years 5 months ago #74111
by jimnydms
Replied by jimnydms on topic Re:Spacers
Hi thanks for all your help much appreciated
- pkitchen123
13 years 5 months ago #74117
by pkitchen123
I torqued all mine to 70, and as expected the alignment wasn't quite right for the spacer to fit over the studs. I then had to very slightly slacken and tighten each stud to get the spacer to fit properly.
- reaper
13 years 5 months ago #74152
by reaper
Replied by reaper on topic Spacers
I have those type on and had no problem with them
The torque setting as i understand is for the wheel nuts as if you overtighten them it will strip the thread on the extension , there is no way you could torque the studs on to the hub as you need that adjustment for alighnment .
Once the spacer is on there is no way for the extension studs to work loose as the holes in the soacer prevent and turning of the stud
- jimnydms
13 years 5 months ago #74182
by jimnydms
I spoke to the graystone guy who makes them and he said as above torque the studs to 70ft lb (94NM) and back them off slightly for the desired position then slot the spacer over. Then torque the nuts on as per usual once the wheel is on
Time to create page: 0.084 seconds
