Advice required
  • shooter1122
14 Jun 2013 11:00 #73738 by shooter1122
Advice required was created by shooter1122
I have a 1998 Jimny that yesterday passed its MOT with advisorys only. Good news BUT, one of the advisorys relate to blue smoke from exhaust on acceleration. I was aware she was losing a bit of oil but not into the engine. What should I do? Are there any products I could add to the engine oil to prolong engine life. Thank you in anticipation.
  • med
14 Jun 2013 11:36 #73741 by med
Replied by med on topic Advice required
blue smoke on acceleration is usally piston rings, smoke when you let off is usually valve stem seals.
I wouldnt recommend putting anything into the engine, those miracle cure products usually do more harm than good.
Id nurse it along or look at a second hand engine replacemnt would probably be the cheapest option if it gets really bad.
  • markyp2000
14 Jun 2013 15:05 #73753 by markyp2000
Replied by markyp2000 on topic Advice required
Blue smoke on start up id say valve stem seals
Blue smoke on deacceleration is piston rings
Blue smoke on acceleration could be blocked breather on the engine or piston ring
I rebulit my engine due to this and put new piston rings and new valve guides and seals in and all sorted
  • gus2000
14 Jun 2013 15:50 #73756 by gus2000
Replied by gus2000 on topic Advice required
med wrote: I wouldnt recommend putting anything into the engine, those miracle cure products usually do more harm than good.
markyp2000 wrote: Blue smoke on acceleration could be blocked breather on the engine or piston ring
I fully agree. begins by reviewing the PCV valve and its connections N° 12 and pipes 11 and 13 in the picture
Check pcv valve :huh: in spanish :huh:
  • shooter1122
14 Jun 2013 16:20 #73759 by shooter1122
Replied by shooter1122 on topic Advice required
Thank ou all for your replies. Will. Check the breathers first and go from there
Time to create page: 0.204 seconds
