play in the steering ?
  • idiotmobil
12 Jun 2013 16:20 #73583 by idiotmobil
play in the steering ? was created by idiotmobil
if got a problem with the jimny with the front up on axle stands with front wheels in the air I can hold the tyre front and back and theres some play I cant fine were its coming from if been at it for some time now and 3 of us have tried to find it but no luck is there any thing common I should be looking at I also have the death wobble I think the jimny been lifted 2" with shocks and springs shock relocaters if fitted steering damper, caster correction bushes, but its still there ive been told maybe maybe its the kingpin bearings but I thought that would be paly if I had the top and bottom of wheel I inspected them today and they seam good but ordered some new ones anyway any help on what to check would be great as im abit stumped at the moment
  • markyp2000
12 Jun 2013 17:07 #73589 by markyp2000
Replied by markyp2000 on topic play in the steering ?
Are you holding it at 6 & 12 or 3 & 9 and getting the play
  • idiotmobil
12 Jun 2013 18:22 #73596 by idiotmobil
Replied by idiotmobil on topic play in the steering ?
3 and 9 front and back not top and bottom
  • markyp2000
12 Jun 2013 18:34 #73597 by markyp2000
Try doing it with one wheel jacked up at atime and look very close to the track rod ends and the steering box joint
  • idiotmobil
12 Jun 2013 19:08 #73604 by idiotmobil
I checked track rod ends they look ok but both were in the air ill try with one were about is the steering box joint. To me the play seams like it mite be high up in the steering if that makes sence
  • markyp2000
12 Jun 2013 19:46 #73607 by markyp2000
On the end of the pitman arm and the to UJs in the engine bay on the steering coloum shaft
Time to create page: 0.089 seconds
