Fitting 31" tyres
- Thank you received: 252
10 Jun 2013 21:17 #73449
by j999pre
Grey pick up Jimny
Fitting 31" tyres was created by j999pre
At the mo I have 235 75 15 muds but want to go bigger.
Will my 3" lift be enough with trimming?
Grey pick up Jimny
- hypo81
10 Jun 2013 21:24 #73450
by hypo81
Replied by hypo81 on topic Fitting 31" tyres
Hi james u have a pm
- supergaz
10 Jun 2013 21:26 #73451
by supergaz
Replied by supergaz on topic Fitting 31" tyres
I don't think its down to lift, its all down to trimming as the wheel needs to fit inside the arch to flex. Then it needs to be able to steer when flexed.
I've recently lowered mine and plan on bigger tyres.
10 Jun 2013 21:37 #73452
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Fitting 31" tyres
Cheers, I've a big belief in trying to keep it low but getting as much axle clearance as I can. That is why I'm trying to avoid a body lift.
Grey pick up Jimny
- supergaz
10 Jun 2013 21:45 #73455
by supergaz
My 235/75/15 special tracs rubbed with 4.5 suspension lift and 2" bodylift and trimmed arches when on lock.
So the plan now is to remove the seams at the rear of the arches and by the sill and maybe take an inch out of the sill.
So no matter how much lift you have, the tyres still need to fit inside the arch to flex and get full lock.
- Basketcase
10 Jun 2013 21:51 #73457
by Basketcase
Replied by Basketcase on topic Fitting 31" tyres
I've got 235/75/15 malatesta kobra on a 3" lift with non-corrected arms and it doesn't seem to rub when I'm offroad it does rub when I hit a left hand bend fast though but it's on the little plastic bit that's holding my plastic wing extension to the body
Time to create page: 0.209 seconds
