Caliper bleed nipples
- Gromit
13 years 5 months ago - 13 years 5 months ago #73227
by Gromit
Caliper bleed nipples was created by Gromit
Does any body know the size of the bleed nipples on the front brake calipers and is the rear drum one the same size ?
Last edit: 13 years 5 months ago by Gromit.
- macguyverjimny
13 years 5 months ago #73239
by macguyverjimny
Replied by macguyverjimny on topic Caliper bleed nipples
The front use a 10mm metric ring spanner for the caliper, on both sides,
The rear uses a 8mm metric ring spaner ,
Dont know if this is what you are after?
- GuardianAngel
13 years 5 months ago #73241
by GuardianAngel
Replied by GuardianAngel on topic Caliper bleed nipples
If your after the thread sizes, then this might help:
www.bigjimny.com/index.php/forum/7-jimny...ront-and-rear-brakes
- Gromit
13 years 5 months ago #73277
by Gromit
Replied by Gromit on topic Caliper bleed nipples
Cheers, it was the thread size I was after so I now know the fronts are 10mm x 1.0, just need to find out what the rear one is now !
Time to create page: 0.087 seconds
