3 link front suspension
  • markyp2000
05 Jun 2013 19:59 #72892 by markyp2000
3 link front suspension was created by markyp2000
How hard is it to fit/make a 3 link set up on my front axle OR make brackets and trailing arms to sit on top of the axle OR how much for some one to make up a kit i can weld on inc arms and joins etc
  • TomDK
05 Jun 2013 20:04 - 05 Jun 2013 20:08 #72894 by TomDK
Replied by TomDK on topic 3 link front suspension
It's not something you just make overnight, using only your eyes for measure. Everything needs to be aligned properly.
If you want to know how much for someone to make it. You're better of asking that someone, instead of here :P
I would try contacting ORA, they have the skills for making stuff like this :)
Last edit: 05 Jun 2013 20:08 by TomDK.
  • markyp2000
05 Jun 2013 20:07 #72895 by markyp2000
Replied by markyp2000 on topic 3 link front suspension
But there are people on here that are more than capable of doing it id rather give a one man band ago before a compony to rip me off
  • mudman
05 Jun 2013 23:06 #72908 by mudman
Replied by mudman on topic 3 link front suspension
try rockwatt but why would you want your arm on top of the axle? :unsure: :S :blink: i cant see how that would help try using KAP arms witch sit the same hight as stock arms or ORA are bringing out new arms soon that sit higher then stock
  • TomDK
05 Jun 2013 23:36 - 05 Jun 2013 23:41 #72910 by TomDK
mudman wrote: try rockwatt but why would you want your arm on top of the axle? :unsure: :S :blink: i cant see how that would help try using KAP arms witch sit the same hight as stock arms or ORA are bringing out new arms soon that sit higher then stock
One arm on top of the axle/diff housing is the whole idea of a 3 link. It is to prevent the axle from rotating, as you don't use standard radius arms, but arms that attach only to the rear of the axle. This gives much better articulation.
More pics and a complete kit here:
www.tmrcustoms.com/store/index.php?main_...nfo&products_id=1276
Last edit: 05 Jun 2013 23:41 by TomDK.
  • markyp2000
06 Jun 2013 06:59 #72913 by markyp2000
Mounting the arms over the top was just an idear while sitting having a fag as i had a spring over axle on my sj i just wondered if it was possable to do the same with the arms to get them right out the way
Time to create page: 0.170 seconds
