Spedo wiring
- Johnniehec
Topic Author
- Thank you received: 56
13 years 5 months ago #72832
by Johnniehec
Spedo wiring was created by Johnniehec
Does anyone know which colour wires or connector by the steering column is the spedometer wiring?
Daughters Jimny (little Jimny) got a telemetrics unit fitted on the 24th May, to reduce her new drivers insurance premium and the spedo stopped working on the 2nd June! I've checked the plug and wiring at the transfer box and it's all OK. The insurance smallprint states "Thou shalt not, nor allow anyone else to, interfere with, disconnect or even glance casually at the unit" "If you do so you may be liable for massive financial penalties or even death".
Thinking it was a bit of a coincidence and not knowing if the unit is physically connected to the spedo wiring I gave them a call, "yes we'll certainly send an engineer to check it out, but if it's nothing to do with the unit we'll charge you £50".
When I pointed out that it'd only been fitted a week, their terms and conditions state..... and asked if I took it to a garage and the mechanic said "it's the telemetric unit that's causing the problem" would they cover the garage bill? They agreed to send someone out on the 21st June "we might have dislodged a wire" So we'll see what happens.
In the meantime I'd like to identify which wire it might be.
Cheers,
John.
Cheers,
John.
- dirtydogz
13 years 5 months ago #72893
by dirtydogz
Replied by dirtydogz on topic Spedo wiring
When my speedo stopped work, I just disconnected the battery for 2 mins then reconnected it and it's still working after 6 mouths.
13 years 5 months ago #72896
Replied by mlines on topic Spedo wiring
We have just had a similar unit fitted to our LittleJimny as well. It only has 3 wires which I assume is positive, ground and ignition. (No I didn't look, honest Guv. The engineer sought my advice in case I knew something about Jimnys)
THerefore I guess all the speed/time/distance calculation is done by GPS I assume
Was it "inthebox" insurance, they seem very competitive for teenage drivers if you have the black box fitted.
£1390 for a 17 year old new driver on day he passed his test, everywhere else was over £2000
- med
13 years 5 months ago #72916
by med
Replied by med on topic Spedo wiring
look at the speedo sensor on the rear of the transfer box for wire colours, i know the speedo pulse wire is either green with yellow trace or yellow with green trace!! the other two wires on the sensor are +12v and a ground. The blue one is +12v.
hope this helps
hope this helps
- Johnniehec
Topic Author
13 years 5 months ago #72996
by Johnniehec
Replied by Johnniehec on topic Spedo wiring
Martin, no it's Bell through money supermarket £1180 just after her 18th. Twin sister Pug 206 1 yr ncb (policy was in her name when they were learning) £990. Bit of a faff getting both with Bell as the online quotes thought they were the same person and they couldn't do two black boxes over the phone, had to go through Confused to get the second one.
Thanks med, I should have thought of that.
Cheers,
John.
Cheers,
John.
Time to create page: 0.084 seconds
