CREAK!
  • roo_presents
31 May 2013 14:29 #72312 by roo_presents
CREAK! was created by roo_presents
Hey guys
Anyone know, that when under load, i.e. turning slowly onto my drive, I get a creak from the front end? I have leaned against the front offside wheel and pressed against it and there is a slight creak from this?
Any suggestions before I go and spend some time in a garage diagnosing faults and stuff?
Could it be a dry joint? Anything to be majorly concerned about?
For the record, I have not taken her off road so to speak, only up a pot holed forest track, but the creak was there before then. Nothing happens going over bumps ala speed bumps but it's just slightly annoying.
Cheers for the input, I look forward to hearing from you!
Roo :unsure:
31 May 2013 15:38 #72314 by facade
Replied by facade on topic CREAK!
Mine creaked when parking because the swivel bearings (kingpin bearings) were as rusty as old iron.
New ones cured it.
Won't hurt to change them, they are always gone. (unless you fitted them yesterday ;) )
  • markyp2000
31 May 2013 16:57 #72325 by markyp2000
Replied by markyp2000 on topic CREAK!
Anti roll bar bushes/links
Panard rod bushes
Shock absorber
Spring not seated right
One of the 4 track rod ends
  • roo_presents
31 May 2013 20:26 #72340 by roo_presents
Replied by roo_presents on topic CREAK!
cheers chap, 2009 model with 8000 on the clock?
i'll pass this info onto my mechanic mate and check it out!!
much appreciated!
