Lost my Propshaft!!!
- Smoggy
29 May 2013 21:00 #72148
by Smoggy
Lost my Propshaft!!! was created by Smoggy
Hi can anyone please remind which propshaft is used to go from my SJ transfer box to the front differential. Is it a Jimny rear propshaft?
The reason, I believe I have LOST my front prop when I dismantled the front end to repair my diff doh.. :S
29 May 2013 21:06 #72150
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Lost my Propshaft!!!
Nope mine uses the standard jimny front prop on the front. Sj front prop on the back.
Grey pick up Jimny
- Smoggy
29 May 2013 21:35 #72159
by Smoggy
Replied by Smoggy on topic Lost my Propshaft!!!
Does anyone know where sells a heavy duty replacement for a jimny front prop. Also on a standard SJ transfer box are the two output flanges the same size and bolt pattern does anyone know.
- ne-crock
29 May 2013 22:12 #72173
by ne-crock
Replied by ne-crock on topic Lost my Propshaft!!!
your so tidy and organised how did you manage to lose a part of your car :S
30 May 2013 07:00 #72181
by j999pre
Grey pick up Jimny
The output flanges tend to be the same but can vary depending on who built the box and which props they were going to fit.
My front output was a samurai one I think so matched the jimny front prop. You can swap the sliding joint from the sj props onto the jimny front prop to match the box you have or some people redrill the flange.
Not sure on heavy duty props but seem to remember something about toyota surf (import) props being usable with a bit of machining to the register ring? Don't hold me to that though
Grey pick up Jimny
- adamatdraycott
30 May 2013 11:22 - 30 May 2013 11:25 #72198
by adamatdraycott
Replied by adamatdraycott on topic Lost my Propshaft!!!
Fairly certain Darth has a heavy duty prop on his
Think he had it made bespoke.
PM him and ask for details.
Last edit: 30 May 2013 11:25 by adamatdraycott.
Time to create page: 0.182 seconds
