New Week, New Problem...
  • markyp2000
28 May 2013 20:01 #72014 by markyp2000
Replied by markyp2000 on topic New Week, New Problem...
Also check the wires on the tranferbox there is a switch that operates the solenoid to allow the hubs to lock in
  • Grizzly
28 May 2013 20:13 #72015 by Grizzly
Replied by Grizzly on topic New Week, New Problem...
I did think it must be something to do with the transfer box but I'm not 100% as to where I'll find the wires :huh: I had the engine running when I checked whether the hubs locked in or not.
  • markyp2000
28 May 2013 20:51 #72023 by markyp2000
Where the rear prop comes out there are to items with wires one the speed sensor and the other is the 4wd switch i think its the top one of the to
Best thing to do is pull one pipe of at atime where the front trailing arm bolts to he chassis and ge some one to select 4wd and see it is sucks on your finger on pipe sucks on and the other sucks off the hubs
On the inlet manifold after the throttle housing on the left hand side as you look at it there is a small pipe about half way down that some times splits
  • Grizzly
28 May 2013 21:13 #72032 by Grizzly
I'll have a look tomorrow afternoon, got a s**t of a job to do in the morning :angry:
28 May 2013 22:15 #72043 by facade
Replied by facade on topic New Week, New Problem...
If the vacuum system is faulty, the green 4wd lamp will flash. As it isn't doing anything, the fault is most likely the switch on the transfer box, the wiring to it, or a fuse.
If you can find the 4wd controller, pin 7 which is blue/black wire connects to the switch, reads 12V in 2wd 0V in 4wd. Sticking a pin through this wire will let you meter it, grounding it should activate the hubs and the green light.
Probably easier to look for a wire off at the switch on the transfer box though.
  • vitara_mad
28 May 2013 23:01 #72048 by vitara_mad
Replied by vitara_mad on topic New Week, New Problem...
I had same problem first thing I checked was the switch on transfer box but that was fine & never did find the problem so just solved the problem the best way by fitting manual hubs
