Help please, jimny wont start.
  • jacques
13 years 5 months ago #71903 by jacques
Help please, jimny wont start. was created by jacques
Hi everyone, I'm Barry. I'm new to this site but recently bought a Jimny and am hoping to get some advise from someone who knows about these.
It is W reg 2000 1.3. old style single cam. Firstly this had a problem with cutting out when hot and then not starting until it had cooled. The owner of the car decided she wanted a head gasket doing. I was doing the gasket but some of the head bolts completey rounded off, so now I have the car and decided to put an engine in it. I've done that today but now the engine wont start, it turns over but doesnt fire. Its not getting a spark and doesn't seem to be getting fuel to the injectors. I removed the fuel pipe and fuel does seem to getting pumped to the rail. As far as I can see everything is connected but I'm open to suggestions as to what I might done wrong.
Any help is massively appreciated.
Thanks guys.
Barry
13 years 5 months ago #71905 by j999pre
Did out come with two keys? If so try the other as it sounds immobilizer ish? Nothing shorted out whilst doing the swap? Also check the earth on the front of the inlet manifold. Little 10mm bolt.
Grey pick up Jimny
  • jacques
13 years 5 months ago #71909 by jacques
Replied by jacques on topic Help please, jimny wont start.
I cleaned that earth up. I only have one key but I was thinking immobiliser area. I don't think I shorted anything as I had the battery off but I'll have a check of the fuses.
Thanks.
13 years 5 months ago #71912 by j999pre
Whereabouts are you? If your local I have an ecu, immobilizer, reader etc you could try? Is the car a hard top?
Grey pick up Jimny
  • markyp2000
13 years 5 months ago #71913 by markyp2000
Replied by markyp2000 on topic Help please, jimny wont start.
Did you swop over all the old parts sensors etc may be it could be the cam shaft sensor also is it a hard or soft top as the engines are different between the to
  • jacques
13 years 5 months ago #71917 by jacques
It's a soft top. I'm in Sunderland.
The engine came from a wagon r so I had to swap most of the parts over. I put the original cam sensor on as I thought the one on the new engine might be different.
Time to create page: 0.089 seconds
