engine light staying on
  • garrygun
26 May 2013 18:55 #71801 by garrygun
engine light staying on was created by garrygun
Hi guys,my jimny 2002 engine light came on and stayed on, it runs & drives ok,
any ideas what could be the problem? any help would be greatly apreciated .
Thanks Garry.
  • discotroll
27 May 2013 18:40 #71900 by discotroll
Replied by discotroll on topic engine light staying on
You really need to get a code reader and plug it in (others on here are best suited to tell you which you'll need, depending on which engine, etc, you've got).
Could be almost anything - my light came on and when I read the code it was for a 'random misfire' :blink: Everything was running just fine so I put some engine cleaner in my fuel and it never came back - unfortunately the light covers everything from that through to larger issues....
  • jacques
27 May 2013 18:52 #71904 by jacques
Replied by jacques on topic engine light staying on
Most likely to be Cam or crank sensor but you really do need to get a code reader on there.
  • garrygun
27 May 2013 20:06 #71920 by garrygun
Replied by garrygun on topic engine light staying on
Thanks guys, are these code readers expensive?
27 May 2013 20:13 #71924 by mlines
Replied by mlines on topic engine light staying on
You have to identify which age/version of Jimny you have. If its an OBD2 based ECU then the cheap readers on EBay will work. Otherwise you will need the reader in my store.
  • garrygun
27 May 2013 20:26 #71927 by garrygun
Thanks Martin, its on a 51 plate i think its original engine.
Time to create page: 0.166 seconds
