Broken Jimny
- m6avh
23 May 2013 15:20 #71461
by m6avh
Broken Jimny was created by m6avh
So coming off the motorway, it starts misfiring, having just filled up I paniced and thought I had put in diesel so drove to a garage and put a full tank of premium unleaded high octane and injector cleaner. Driving it up and down at country lane to try and flush it through with no luck....
I got it home and let it cool off, realizing I am 100% sure I had put unleaded in the car I went to investigate. I took out the ignition coils and check the spark plugs. Ha! there was a damp coil so pulled it out and the spark plug was loose to took it out and it had burt out and the conductor pin had disappeared or burn away....
even worse. its got a helicoil on it which came out with the spark plug and its bonded to it without a way to get it off. I have a new set of plugs and ordered a replacement helicoil which I will sort out this weekend hopefully.
Do you guys have any advise?
Also, how hard is it to replace a cylinder head block?
Cheers!
Cheers!
- nicho
23 May 2013 15:42 #71464
by nicho
Replied by nicho on topic Broken Jimny
just make sure nowt drops into the engine when refitting prob best to take head off especially if you have ta run a tap down it, had that problem with a nova sr some one had stuck the plug in with filler i found out coz it was misfiring i opened bonnet and the plug shout out just missin my head n landed otherside of the car park i was on.
- m6avh
23 May 2013 15:49 #71465
by m6avh
Replied by m6avh on topic Broken Jimny
How complicated is it to remove the head?
23 May 2013 16:11 #71468
by kirkynut
Replied by kirkynut on topic Broken Jimny
A singe cam is quite easy, a twin cam is a bit more involved and not looked into to it, but I shouldn't think it's too hard.
- discotroll
25 May 2013 13:08 #71696
by discotroll
Replied by discotroll on topic Broken Jimny
As Kirkynut says, if it's a single cam it's a breeze - just download the service manual so you know the torque settings and bolting order when you put it back on....
- m6avh
28 May 2013 14:54 #71966
by m6avh
Great, so I have got the spark plug helicoil fixed and a new spark plug. It is still misfiring.
Basicly the spark plug came loose, burn out and the pin/electrode dropped out. I have got the thread fixed but its still misfiring. :huh:
Do you have any ideas?
Is the ECU still not firing the cylinder because there was a previous fault? could it be the coil and could it be the valves?
Thanks
Thanks
Time to create page: 0.164 seconds
