17 May 2013 16:43 #70927 by maverick
Torque Settings was created by maverick
Wheel bearing lock nut 220Nm
Pitman arm nut 135Nm
Transfer box flange nut 130Nm
Crankshaft timing belt pulley bolt 128Nm
Pulley nut 111Nm
Wheel nut 95Nm
Jalapeño, IISY?
  • markyp2000
17 May 2013 17:39 #70937 by markyp2000
Replied by markyp2000 on topic Torque Settings
maverick wrote: Wheel bearing lock nut 220Nm
Pulley nut 111Nm
Wheel nut 95Nm
It take it that 128nm on the crank shaft bolts is for the center bolt not the small ones and is this for a twin or single cam engine
  • UKDAN
17 May 2013 17:46 - 17 May 2013 17:50 #70938 by UKDAN
Replied by UKDAN on topic Torque Settings
Ye this is where difficulties could arise with this thread, the settings "Maverick" started the thread with were taken from my post in the "torque wrench" thread which are for the early G13BB single cam engine & I've now modified that post to state this.
Dan
Last edit: 17 May 2013 17:50 by UKDAN.
  • winter
18 May 2013 20:01 #71017 by winter
Replied by winter on topic Torque Settings
theses torque settings are all wrong iv just fitted a m16 into mine and got all the torque settings from SUZUKI yours are way out and if you dont believe phone suzuki and ask them yourself :P
Pulley nut 111Nm
Wheel nut 95Nm
  • UKDAN
19 May 2013 09:44 #71045 by UKDAN
winter wrote: theses torque settings are all wrong iv just fitted a m16 into mine and got all the torque settings from SUZUKI yours are way out and if you dont believe phone suzuki and ask them yourself :P
Pulley nut 111Nm
Wheel nut 95Nm
The M16 is a bigger non Jimny engine so would expect the torque settings listed to different & wrong.
Dan
  • UKDAN
19 May 2013 15:14 #71059 by UKDAN
The settings listed were taken from the early G13BB workshop manual so are correct.
Dan
Time to create page: 0.176 seconds
