URGENT HELP PLEASE
- gaz3359
17 May 2013 09:40 #70898
by gaz3359
URGENT HELP PLEASE was created by gaz3359
9/10 it will be the crankshaft sensor common on alot of vehicles not just jimnys.ive not had alot to do with the gb engine but sure it will be that.have you tried searching ?
17 May 2013 09:43 #70899
by j999pre
Grey pick up Jimny
Replied by j999pre on topic URGENT HELP PLEASE
A g13bb will only have a cam sensor at the rear of the head. The soft top has the crank sensor on the g13bb. Apart from real early ones.
Double check its the g13b
M13a have both
M13a have both
Grey pick up Jimny
17 May 2013 09:45 #70900
Replied by mlines on topic URGENT HELP PLEASE
17 May 2013 10:42 #70905
You said it had a G13BB??
"W" reg is on the transition.
Look at the VIN number. If it contains FB33 then its a G13BB, if it contains FB43 then its an M13AA
Time to create page: 0.148 seconds
