Lower a jimny
- laikathedog
- Junior Member
- Thank you received: 1
14 May 2013 22:38 #70741
by laikathedog
Lower a jimny was created by laikathedog
Hello,
Standard jimny other than 32mm spacers.
My dog is too small to Make the leap into the back, or maye too lazy.
I am toying with all wearing the jimny.
I figure I will need custom springs and dampers, and that while you are all lifting; the same companies can supply the opposite ?
Or can you still get those bolt kits to clamp your spring together ?, haven't seen them since the 80's !
Any guidance appreciated ( other than replacing the dog !)
- markyp2000
14 May 2013 23:47 #70744
by markyp2000
Replied by markyp2000 on topic Lower a jimny
Get a fold up dog ramp and get it to walk up it
It is possable to lower it but it will ride like its driving over a wash bord all the time plus prop shaft may hit the tank and front axle may hit the sump
- gilburton
15 May 2013 09:28 - 15 May 2013 09:29 #70759
by gilburton
Replied by gilburton on topic Lower a jimny
As said get a dog ramp. Plenty on ebay!! They're not expensive or make your own!
Any reason why you just can't lift the dog??
Last edit: 15 May 2013 09:29 by gilburton.
- TomDK
15 May 2013 10:15 #70762
by TomDK
A small dog, so it's along way down to lift it. And/or the owner is just a lazy as the dog :laugh:
Replied by TomDK on topic Lower a jimny
gilburton wrote: As said get a dog ramp. Plenty on ebay!! They're not expensive or make your own!
- GuardianAngel
15 May 2013 10:26 #70763
by GuardianAngel
Replied by GuardianAngel on topic Re: Lower a jimny
Get a fold up dog...
- adamatdraycott
15 May 2013 11:30 #70764
by adamatdraycott
Replied by adamatdraycott on topic Re: Lower a jimny
A set of springs and dampers will cost near £500 ish
Lethal injection is £40
Time to create page: 0.277 seconds
