ora rear bumper
- chrisharman
13 years 6 months ago - 13 years 6 months ago #70682
by chrisharman
ora rear bumper was created by chrisharman
Im thinking of buying a ora rear bumper,does it bolt onto
the standard bumper fitment or do you have to weld few parts on?
The problem ive got is were the bumper bolts onto the arch it has rusted away.
Ive made a bracket for the meanwhile but i dont think it will last a heavy off roading session.
Anyone else had this problem Or has anyone cut down there rear bumper?
Any pics would help?
Chris
Chris
Last edit: 13 years 6 months ago by chrisharman. Reason: adding more information
- Sponnie
13 years 6 months ago #70685
by Sponnie
Replied by Sponnie on topic Re: ora rear bumper
Brackets for the bumper are bolted to the chassis rails. The bumper then mouts to the bracket. Very strong.
Sent from my GT-I9300 using Tapatalk 2
- Smoggy
13 years 6 months ago #70728
by Smoggy
Replied by Smoggy on topic ora rear bumper
Very strong and functional as Sponnie says. Fairly straightforward fit too.
Just use the mounts against the outside of the chassis leg as a template to drill your bolt holes.
You will then need to bolt through the chassis legs and mounts (a bit fiddly but not too bad).
Attach the lower bolts on both sides and do them up slack this will allow you to hinge the bumper down over so you can push together your light plugs, then fit the top bolts and tighten them all up.
Hey presto.
Hey presto.
- chrisharman
13 years 6 months ago #70776
by chrisharman
Replied by chrisharman on topic ora rear bumper
This is how it looks at the moment.
- Sponnie
13 years 6 months ago #70785
by Sponnie
Replied by Sponnie on topic ora rear bumper
eww nice! i'd tackle that before fitting the bumper. But like we have said, the ORA bumper does not mount off the body.
So sort the rust and out, and bolt the ORA bumper on
Time to create page: 0.090 seconds
