Front Diff problems
- The Dug
11 May 2013 20:05 #70504
by The Dug
Front Diff problems was created by The Dug
Hi all,
The Jimny's been making a kind of creaking/grinding noise when I reverse, not idea what it is.
Local garage looked at it today and best guess is the differential.
I don't actually know what this means in terms of cost or mechanics.
Can anyone offer any insight or advice?
Cheers
Cheers
- supergaz
11 May 2013 21:41 #70513
by supergaz
Replied by supergaz on topic Front Diff problems
Is it in 4wd? Think your garage need to give you more detailed information. The jimny is very simple mechanically.
- Thank you received: 115
12 May 2013 12:01 #70528
by maverick
Jalapeño, IISY?
Replied by maverick on topic Front Diff problems
it could be the rear brake shoes rubbing - mine does in reverse or maybe the UJs.
are you sure noise is coming from rear?
its gonna take a lot of thrashing to destroy a Diff, and to be quite honest the diff woul dmake a nosie forwards or backwards if its broken.
Jalapeño, IISY?
The following user(s) said Thank You: The Dug
- The Dug
12 May 2013 12:53 #70532
by The Dug
Replied by The Dug on topic Front Diff problems
Usually in 2WD I can't say for certain if it does it in 4WD too.
- The Dug
12 May 2013 12:56 #70533
by The Dug
I'm actually fairly sure it's coming from the front.
Now that you mention it the brake callipers sticking was picked up at the service and slipped my mind.
12 May 2013 16:15 #70551
by kirkynut
Replied by kirkynut on topic Front Diff problems
Check the radius arm bolts don't need nipping up and that their bolt holes on the chassis brackets / axle brackets are not elongated. Check all 4 corners as noises can sound like they are coming from the other end of the car to the end they are coming from.
