wheel studs
  • ne-crock
11 May 2013 16:45 #70492 by ne-crock
wheel studs was created by ne-crock
just a quick one,
are the studs in the hubs replaceable as in the ones which your wheels attach to,
one of my nuts has decided its came loose but also torn itself apart and got stuck on the thread if i can get the nut off is it possible to just replace the stud and the bolt?
or is it a new hub job?
cheers
11 May 2013 19:00 #70500 by facade
Replied by facade on topic wheel studs
The studs just press out, and a new one presses in.
It is possible to knock them out with a hammer, and draw the new one in with the nut if you are careful.
You might find that you can save the old one if you can remove what is left of the nut.
12 May 2013 16:27 - 12 May 2013 20:53 #70554 by kirkynut
Replied by kirkynut on topic wheel studs
Muddyzook sell longer ones which may or not be cheaper than standard ones - I've seen standard ones for sale on one of the usual Jimny modification companies but having just had a quick look on the BigJimny shop, Bits4Vits and Jimnybits websites I can't find it - have a better look yourself or see what a dealer can do one for.
Edit: found them on Bits4Vits website under Vitara parts. I'd be pretty sure they are the same as a Jimjam's studs.
Last edit: 12 May 2013 20:53 by kirkynut.
Time to create page: 0.154 seconds
