Rose Joints?
- Smoggy
09 May 2013 21:59 #70377
by Smoggy
Rose Joints? was created by Smoggy
- hypo81
10 May 2013 07:10 #70389
by hypo81
Replied by hypo81 on topic Rose Joints?
for the tie rod ends i would go to the shop on here martin will help u out with them
and for the rose joints i emailed off road armoury amd they put me i touch with www.mcgillmotorsports.co.uk/ i give them a ring and had them the next day
- bigoffroader
10 May 2013 11:02 #70399
by bigoffroader
Replied by bigoffroader on topic Rose Joints?
As above I use mcgillmotorsports for all my rose joints, great variety for all pockets and excellent service.
Martin will have the track rod ends but if you need them fast your local auto spares should be able to get you them the same day. Dosen't matter if its for the steering arm or track rod they are the same size you just need to tell them which side you want as they are handed, left and right threads.
- Dave cc
10 May 2013 16:59 #70414
by Dave cc
Replied by Dave cc on topic Rose Joints?
Think what Smoggy is asking is the thread size will be M16x1.5 on them mate L/H thread one side and R/H thread the other
generally a M16 rod end will come withe a 16mm hole in the rod end eye as well but there are exceptions i normally just bush then down to suit
McGill Motorsports do rubber gaitors to go over then as well if you have room to fit them well worth it if you can will allow you to fill it with grease and keep the water out give them a call always helpfull and buy there better quality range worth it in the long run
- Smoggy
10 May 2013 19:49 #70425
by Smoggy
Replied by Smoggy on topic Rose Joints?
Thanks guys for the advice.
