Jimny vvt transfer option
- macguyverjimny
09 May 2013 19:52 - 04 Jun 2013 07:05 #70360
by macguyverjimny
Jimny vvt transfer option was created by macguyverjimny
Hi guys ,
Any idea on which other manufacuter's divorced transferbox will be simmiliar to an sj /jimny trying to find a solution for a vvt jimny's gearing?
Like a landrover ? Or a jeep or isuzu or something?
Any odeas would be appreciated, an sj410 or sj413 wont work too high rpm on highway speeds, and a auto vvt transfercase would be to much hassle to get hold of, it doenst get imported to my country.
Without trying to go the low ratio gearset route,
Any ideas would be appreciated.
Thank you
Thank you
Last edit: 04 Jun 2013 07:05 by mlines.
- topjimny
12 May 2013 15:08 #70542
by topjimny
Replied by topjimny on topic Jimny vvt transfer option
what tyre size do you have in mind?
- macguyverjimny
13 May 2013 07:47 #70599
by macguyverjimny
Replied by macguyverjimny on topic Jimny vvt transfer option
currently 215 75 r15 , but ultimately maybe at a later stage 235 75 r 15,
i however cant find any option on a transfercase swop that isnt a SJ or a sammy case or rocklobster or jimny.
So any help would be appreciated.
Thank you.
Thank you.
- topjimny
13 May 2013 12:12 - 04 Jun 2013 07:09 #70606
by topjimny
Apart from not having the answer you want, i have been researching the gearing subject for awhile, so i hope i can help you.
Going down this path (switching t-case) on VVT Jimny does not worth the job for 235/75r15 IMHO. Unless you are thinking of some very serious off road. If you are thinking bigger than 235, than i'd say go for the swap, as you can gear the Sammy t-case more properly (less in High and more in Low, which cannot be done using low ratio gears).
People use to swap on non-VVT Jimnys and the result is about 25% reduction (which you already have in VVT comparing to non-VVT). The other reason people do this is because the non-VVT have a problem with the chain that slips, but Suzuki seems to have corrected that on VVT with a wider chain (less prone to slip).
If you can understand numbers, here you can find some:
Crawl Ratio VVT (1st gear): 4,425 * 2,002 * 4,300 = 1:38,093
Crawl ratio non-VVT (1st gear): 3,652 * 2,145 * 3,909 = 1:30,621
Not to mention that the 5th gear on the non-VVT is overdrive (0,8x), whilst on the VVT is 1:1.
All manual Jimnys BTW.
Other options apart from touching the t-case or gearbox is start looking fro R&P sets for the VVT Jimny.
I do run 235/75r15 on my VVT and can still climb walls offroading. I mean, it's low enough for my needs. Here is the result (no gearing):
Hope it helps. Good luck!
Last edit: 04 Jun 2013 07:09 by mlines.
- macguyverjimny
13 May 2013 21:03 #70647
by macguyverjimny
Thank you, my problem is just my vvt stalls alot in lowrange, amd my bigest problem is decnts and having to do slow speeds with torque at low rpm over a rocky section,
So i need torque at low rpm where the current m13a preak at 4100 rpm , sometimes i need to ref my car to 3000 rpm and drop the clutch slowly so that one wheel can climp over a rock,
So any help with ring and pinions will help,
Any ideas how to improve this?
Thank you
Thank you
- topjimny
13 May 2013 22:14 - 04 Jun 2013 07:02 #70654
by topjimny
I have found these some time ago:
www.fts4x4.com/en/products/?method=detail&aid=267
I don't know for sure if they will fit our VVT. But if it does, you will have about 6% reduction (back to stock gearing, but running 215/75r15).
Other option is APIO58 Star (reduces only on low range), but bit too expensive and rare. The R&P or low ratio gears will both reduce the same amount on high and low range. With the mildest option, you could end @5000 revs doing 100 km/h on the freeway, even with 29" tires. So not good for a daily... Not to mention that it whines like a floor polisher. Sammy t-case swap starts to look good again.
Let's wait for the other guys answer too. Kind of figure all those things out myself. And I'm a geoscientist, so... i'm as clueless in one sense.
One thing that i'd like to find out too: what are the advantages and disadvantages, if there are any, of gearing through R&P or new t-case gears?
Gearing a VVT Jimny is not a cheap and/or easy task though. I have heard about using auto t-case on manual Jimnys... Have to research a little more about that. But where i live, auto Jimnys simply don't exist.
cheers,
TJ
cheers,
TJ
Last edit: 04 Jun 2013 07:02 by mlines.
Time to create page: 0.098 seconds
