M16a engine
  • RichiesJimny
09 May 2013 10:33 #70322 by RichiesJimny
M16a engine was created by RichiesJimny
I've got an m16a engine on it's way to me what I would like to know in advance is which bits I need to swap off the 1.3 to the 1.6 engine
  • supergaz
09 May 2013 18:50 #70352 by supergaz
Replied by supergaz on topic M16a engine
www.auszookers.com/forum/viewtopic.php?t=30308
I'm doing mine very soon as I have a M16a ready, this link is very helpful.
  • winter
09 May 2013 21:10 #70369 by winter
Replied by winter on topic M16a engine
hello buddy iv just put a m16a into my jimny 6 week ago right you just need a bare block m16a and use all your 1.3 parts on it change the sump over change rockercover change exh manifold n inlet manifold change bottom pully change flywheel , starter motor , th-stat n water pipe , oil filter thread.
remove 3rd eng mount (studs) use the 1.6 injeters not the 1.3 ones thinks that about it it took me and a mate 12hours start to start up ill find you the tq settings you need iv got them at my work or phone suzuki like i did iv got the tq settings for the flywheel,rocker cover,bottom pully,inlet n exh manifold,sump,gearbox/clutch leet me know if ya want them apart from all that the eng just slips n bolts state in
i have more power now its so much better now with the m16 in iv seen 95 mph in her
o what car the m16a eng out of ?
spk soon good luck
RichiesJimny wrote: I've got an m16a engine on it's way to me what I would like to know in advance is which bits I need to swap off the 1.3 to the 1.6 engine
  • winter
09 May 2013 21:12 #70370 by winter
good link buddy
supergaz wrote: www.auszookers.com/forum/viewtopic.php?t=30308
  • gaz3359
09 May 2013 21:13 #70371 by gaz3359
Replied by gaz3359 on topic M16a engine
no messing about here like rich !!!
  • RichiesJimny
09 May 2013 21:55 #70376 by RichiesJimny
Replied by RichiesJimny on topic M16a engine
gaz3359 wrote: no messing about here like rich !!!
We bought our jimnys about the same time Gaz you've almost rebuilt yours and carried out lots of mods all I've managed to do is fit the suspension kit so I thought I'd do some catching up. :laugh:
Time to create page: 0.187 seconds
