anti roll bar removal,
  • ne-crock
07 May 2013 21:24 #70231 by ne-crock
anti roll bar removal, was created by ne-crock
well i've got a couple of clunks i've been trying to figure out what they are,
one is i suspect the anti roll bar which i've been planning on taking off for a while,
went to do it this evening and i couldnt get the drop link bolts undone, they were just spining on themselves
anyone have any tricks or tips for undoing them,
currently got spray on and will repeat untill weekend when i have another go,
cheers
  • mudman
07 May 2013 21:32 #70232 by mudman
Replied by mudman on topic anti roll bar removal,
get the grinder out lol
  • ne-crock
07 May 2013 21:35 #70234 by ne-crock
Replied by ne-crock on topic anti roll bar removal,
that's going to be the last resort, prefer to remove it normaly then gives me the option to put back on if needs be
  • rs200boy
07 May 2013 21:37 #70235 by rs200boy
Replied by rs200boy on topic anti roll bar removal,
good set of mole grips onto rear bit thats spinning as tight as you can jam it whereever possible and remove nut
if still no joy grind it off
  • RichiesJimny
07 May 2013 22:49 #70237 by RichiesJimny
Replied by RichiesJimny on topic anti roll bar removal,
There's quite often two flats on the back of the link so you can get an open ended spanner on to stop it spinning. Jimny might not have them though if not a hacksaw would do it if you don't have a grinder.
  • Smoggy
08 May 2013 06:24 #70242 by Smoggy
Replied by Smoggy on topic anti roll bar removal,
I take on board what your saying about not wanting to use a grinder mate but if you leave the connection points in place the MOT testers are more likely to see it and fail it. Unless your mate at that local garage does it for you of course ;)
Time to create page: 0.095 seconds
