New owner, where do i start?
  • Rasmusok
05 May 2013 16:25 #70057 by Rasmusok
New owner, where do i start? was created by Rasmusok
Hi all!
Finally ive got a Jimny :) 2000, 1.3 Petrol in red.
The sellers told me, that it resently got service check.
I want to be sure, that every thing is ok. Theres no rust, no mechanicle og electrical problems, but, what parts do i want to make sure is okay, what fluids should i change and what kind of service would i need to keep it nice and tidy?
Cheers, the danish guy :D
05 May 2013 18:09 #70071 by facade
Replied by facade on topic New owner, where do i start?
Welcome :)
There are some how to guides on the front page under information.
Basically, pull the dipstick and see if the engine oil looks new, check the oil filter looks new.
Change the oil in the gearbox, transfer box and axles. You need a tool (10mm square) to undo the filler and drain plugs, (undo the filler first, in case it is stuck) and an oil syringe or pump to get oil into the gearbox.
There is also a single grease point on the sliding part of the front propshaft.
If the brake fluid looks brown, change it, but that is a safety item, so best trusted to a mechanic.
When completely cold, undo the radiator cap, and the coolant, not plain water should be right up to the top of the filler, put the cap back and check the level in the plastic tank is on the line.
  • markyp2000
05 May 2013 18:50 #70078 by markyp2000
Replied by markyp2000 on topic New owner, where do i start?
First thing id do is pop the the bank check ya balance and get a loan if needed
  • JivingDaddy
05 May 2013 22:30 #70118 by JivingDaddy
Replied by JivingDaddy on topic New owner, where do i start?
markyp2000 wrote: First thing id do is pop the the bank check ya balance and get a loan if needed
:cheer: Ha, Ha. There speaks the voice of experience.
  • mudman
06 May 2013 07:16 #70126 by mudman
Replied by mudman on topic New owner, where do i start?
you dont need a pump to fill the gear box do as i did get a length of hose and a funnel put 1 end of the hose in tge gearbox filler push the other end up through the engine bay to your mrs who is sitting on the engine :lol: she then poors the oil into the funnle down the hose into the box.......... simples
  • Rasmusok
06 May 2013 07:44 #70127 by Rasmusok
Replied by Rasmusok on topic New owner, where do i start?
Thank you, so far :)
Time to create page: 0.104 seconds
