Hole where jack tray should be
- Osborne
05 May 2013 06:21 #70025
by Osborne
Hole where jack tray should be was created by Osborne
Now I understand that this is a common problem....basically I have a hole where the jack tray should be! Does anybody make a repair panel for this, I know I can fabricate something but a pattern replacement would be much easier. Failing that anyone know of any helpful breakers that MIT cut the part out of a recent write off?
Thanks for your help guys
05 May 2013 07:12 #70028
by kirkynut
Replied by kirkynut on topic Hole where jack tray should be
The are no aftermarket panels, most people repair what they have. Camsuzuki on eBay may help you cutting a panel out of a newer car that's accident damaged if you message them.
The following user(s) said Thank You: Osborne
- JivingDaddy
05 May 2013 07:39 #70032
by JivingDaddy
Replied by JivingDaddy on topic Hole where jack tray should be
It's an integral part of the Jimny ventilation system, leave it alone. :laugh:
- supergaz
05 May 2013 07:41 #70033
by supergaz
Replied by supergaz on topic Hole where jack tray should be
Best just to weld a solid bit of steel in place.
- UKDAN
05 May 2013 08:58 #70037
by UKDAN
Any thing welded in is good as its hidden away out of sight so even if you do a bad job nobody's going to see it
Dan
Replied by UKDAN on topic Hole where jack tray should be
supergaz wrote: Best just to weld a solid bit of steel in place.
Dan
- Osborne
06 May 2013 18:44 #70156
by Osborne
Replied by Osborne on topic Hole where jack tray should be
Thanks for the reply, I've mailed Cam suzuki, failing that.....flat plate I guess :blink:
Time to create page: 0.108 seconds
