Half shafts
- Bendywagon
04 May 2013 15:21 #69987
by Bendywagon
Half shafts was created by Bendywagon
Hi guys just just a quickly ,should there be any up and down movement on the half shaft on the passenger side,replaced kingpins a week ago all seemed fine until today.have developed a rattle just taken apart it all looks ok.apart from slight movement from half shaft.
- Sponnie
04 May 2013 18:01 #69990
by Sponnie
Replied by Sponnie on topic Half shafts
Wheel bearing movement?
- Bendywagon
04 May 2013 19:41 #70001
by Bendywagon
Replied by Bendywagon on topic Half shafts
Thanks for that just tried wheel no movement side to side or up and down.
04 May 2013 21:50 #70012
by facade
Replied by facade on topic Half shafts
If you mean that at the front, with the hub off you can move the splines up and down, likely that is normal, there is nothing inside the stub axle tube to support it
- Bendywagon
05 May 2013 12:26 #70043
by Bendywagon
Cheers for that,been over everything again the only thing I can see is one of the clips that hold brake pad is missing.would this let the pad rattle at all.
05 May 2013 18:03 #70069
by facade
Try brushing the brakes when it is rattling, if it stops, then the rattle is brake related.
Some people report a clicking noise from the hubs if they are partially engaged.
A loud buzzing sound at around 30mph in 4th & 5th is the heat shield loose on the catalyst under the passengers feet.
The following user(s) said Thank You: Bendywagon
Time to create page: 0.164 seconds
