air lock
- Danjamin
03 May 2013 18:11 #69915
by Danjamin
air lock was created by Danjamin
Iv broken down:( how do I bleed the ccooling system I have an air lock. Many thanks
- MWells
03 May 2013 18:36 - 03 May 2013 18:39 #69917
by MWells
Replied by MWells on topic air lock
Park on a level surface, let the car cool down, remove the radiator cap,top up the radiator if required, run the engine up to temperature, carefully top up coolant in radiator, turn off engine once warmed up, carefully top up coolant in radiator, allow to cool, replace radiator cap. The coolant may need topping up as it cools.
Last edit: 03 May 2013 18:39 by MWells.
- markyp2000
03 May 2013 18:58 #69921
by markyp2000
Replied by markyp2000 on topic air lock
And then fill the bottle up if required and make shore your heater is on hot and the heater fan is off if it over heats while driving try opening he windows and putting the heater on hot and full blast
Time to create page: 0.162 seconds
