Clutch cable removal
- Damohick
03 May 2013 07:40 #69883
by Damohick
Clutch cable removal was created by Damohick
Right guys, I'm embarrassed to say I'm struggling with removing my clutch cable. I've removed both ends but can't pull the cable either way through the bulkhead, any tips would've greatly appreciated.
- gus2000
03 May 2013 12:39 #69894
by gus2000
Replied by gus2000 on topic Clutch cable removal
- Damohick
03 May 2013 12:51 #69895
by Damohick
Replied by Damohick on topic Clutch cable removal
Thank you for your reply, it appears I've disconnected the cable from both ends already but it just doesn't seem to want to come through the bulkhead ... Now I know I'm doing the right thing I will try pulling harder
03 May 2013 17:21 #69909
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Clutch cable removal
Probably the clip under the dash holding it. Upside down in the foot well it is then.
Grey pick up Jimny
03 May 2013 21:02 #69937
by kirkynut
Replied by kirkynut on topic Clutch cable removal
From memory if you pull the rubber gromit out of the bulkhead you can see how it attaches to the pedal and do it from the engine bay with ease.
I think I found putting the gromit back in place the hardest part!
- Damohick
03 May 2013 23:05 #69952
by Damohick
Cheers guys, It was indeed the clip behind the pedal ... I've got the little bad boy off now though
